downloaded 100 file movie gangs of ny 2cds i knew that 2cds was not the full movie as it seems like 3cds on a bin file and as i expected it turned out as an avi file dvd screener. when i changed over to mpeg with TMPGE it took 12hrs. again something was wrong 12hrs? after it converted i tried burning it to a svcd with nero everything went wrong got an error message that wav was not in sync pixels in video was something like 525X 256 i thing its supposed to be 480x480 to run correctly. anyway is there any hope? can i change pixels? if anyone can help me can you give me a step by step on how i can get this movie im not that TMPge literate so you have to go slow with me PLEASE HELP!
So you have 2 x 700mb AVI files?
Firstly you need to see if you have all the right codecs installed, if it plays ok in media player then you should be fine... if not then get the Nemo codec pack. Tmpgenc should then accept the AVIs and encode them, just make sure you use the right templates.
For the love of God...Ripping disaster
By GwnLee in forum Authoring (DVD)Replies: 3Last Post: 13th Sep 2011, 17:51 -
Power failure = disaster, any way to salvage?
By PhillT in forum Newbie / General discussionsReplies: 14Last Post: 18th Apr 2011, 01:16 -
Question about Disaster after using Partition Magic
By jimdagys in forum ComputerReplies: 9Last Post: 20th Nov 2009, 11:22 -
JVC S-VHS machine w/ stabilizer "on" plus inline TBC = disaster?
By justin81 in forum RestorationReplies: 8Last Post: 7th Oct 2009, 00:23 -
Disaster Has Struck: Problems w QT update to 7.2.0 player 7.2
By rotuts in forum MacReplies: 4Last Post: 2nd Aug 2007, 05:23
