  1. Hiya,
    I am trying to find a way of converting RM (Real Media) To Mpeg. I have tried "RM Convertor" By Boilsoft, but find that the audio is not in sync with the video!
    Is there a better way? Any way of using on-screen encoders?
    Thank you for taking time to read this, and for any help you may give.
    Nate.
    universe
    you can use tinra or you can adjust the audio in vdub or tmpgenc or you can use real7ime converter
  3. EO video works fine for converting to avi, which you can convert to mpeg then afterwards
  4. Thanks For The Info!
