Hi,
I've got a amd k6-2 300mhz system and can capture with no framedrops at 352x288 25fps using a bt878 chipset capture card since i finally fixed my problem i found out i had a bottleneck on my pci bus since i had a pci 2d video card so i replace it with a 2d agp card and it solved my problem.
I am considering buying an AMD Athlon 1.4ghz
and wanting to know if an abit kg7 motherboard is a good choice for the mainboard and do i need raid support for capturing etc...
also would like to know is there a big difference in quality when capturing from vhs to uncompressed avi at 352x288 25fps pal and 704x576 25fps pal.
Any help would be apreciative
TurboRunner
Take a look at the ASUS A7A266 board. It has provisions for both SDR DIMM's and the newer and much faster DDR memory that runs at a blistering 266 MHz on the Front Side Bus. Plus you can fiddle with the CPU settings from the BIOS.
All the faster AMD CPU's run HOT like 120-130 degrees under load and doing long renderings of video will stress the chip so be sure to have pleny of cooling especially if you plan on overclocking. Why anyone would need to overclock a 1200-1400MHz chip beats me when they run that hot at the recommended clock speed.
You don't need raid. Invest in a large Ultra 100 IDE drive instead or a external firewire drive. Don't forget the required 80 wire cable to prevent crosstalk on the IDE drive.
Should I re-upgrade from Asus/AMD to Gigabyte/Intel?
By Stealth3si in forum ComputerReplies: 23Last Post: 16th Apr 2012, 21:06 -
win a 48 core amd system
By deadrats in forum ComputerReplies: 5Last Post: 8th Mar 2010, 13:54 -
AMD 4200+ Single Core to Dual-Core Upgrade Issue...
By Bodyslide in forum ComputerReplies: 7Last Post: 30th Nov 2007, 16:45 -
WinTV Dropping frames w/ new Dual Core AMD 5600+ system RESOLVED
By DAVE440 in forum Capturing and VCRReplies: 4Last Post: 26th Oct 2007, 22:01 -
AMD 64 4000+(1x2.4GHz) or AMD 64 X2 3800+ (2x2.0GHz)
By neomaine in forum ComputerReplies: 19Last Post: 13th Jul 2007, 11:24
