I've downladed lots of divx movies from internet. Most of them, fit into a normal 700 mb cdr, but some of them don't. Let me tell u guys that I already, did the normal cutting in this divx files(beggining n ending of the movie), but they still too big to fit in a 700mb cdr.
Today, I tried to buy a 90 min cdr that surely would solve my issue, but for my surprise, they cost 3x a normal 80 min cdr here in my hometown.
I have 2 solutions that i know, but they take a long time.
1- Change the audio bitrates of the movie. (but I[m not sure how to do it)
2- Reencode the divx movie using some divx file predictor.
If u guys could give me more ideas or comments....
You should cut the credits iwth VDub, then if you are still tight for space change the audio bitrate.
-davewerd -
[quote="poonaner"]You should cut the credits iwth VDub, then if you are still tight for space change the audio bitrate.
-dave[/quote
Ok, I could try doing that, but how??? N do u know how long it will last this procedure?
Thanxs -
Go to this site https://www.videohelp.com/virtualdubedit.htm. It tells you how to cut out any part (the credits for example) of an AVI. No re-encoding is needed, it just takes time to create a copy of the file without the part you selected to remove.
-Mattdj matty b
Best/Fastest Software for 700MB Movie
By EzK in forum DVD RippingReplies: 5Last Post: 21st Jul 2011, 07:02 -
Reduce file size .
By pensioner in forum Newbie / General discussionsReplies: 4Last Post: 10th Dec 2010, 15:08 -
Reduce file size
By windranger in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2010, 10:18 -
How do I reduce the file size of my 16 meg movie?
By Luckyword in forum MacReplies: 7Last Post: 20th May 2009, 18:53 -
Converting QuickTime movie to Flash to reduce file size
By Vaugust in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2007, 14:28
