There is a very serious performance issue on my PC. My PC is an AMD K6-II 500 Mhz, and i think that's more than enough for playback the Divx movies, or i am wrong???
Back in the time of Divx 3 and 4, the movies ran smoothly. The problem began at Divx 5.02 and better. It just slows down. Almost every movie at a high resollution is seriously slow. 5.03 doesn't even work. I installed Nimo and it didn't work either. XVID runs slow too.
So what it is:
A. Format that crappy C: Drive
B. Download a Magic Program that fixes this thing
C. Buy a better system.
Isn't 500 Mhz enough???!!!
c.
a format wounldn't hurt if you haven't done it in a log time.
uninstall all the codecs and just try the divx 5.02 and see if that helps.
500mhz is the recommended minimum requirements.
Common DivX DVD Players AVI Playback problems!
By Baldrick in forum Newbie / General discussionsReplies: 8Last Post: 6th Jun 2013, 09:32 -
Divx playback problems on DVD Player
By pblunn in forum DVD & Blu-ray RecordersReplies: 4Last Post: 26th Feb 2008, 02:02 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 09:19 -
DivX playback problems on Philips DVP 3040 (since installing WinXP SP2)
By mikester2 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 22nd Nov 2007, 12:54 -
Divx vs. Xvid performance on portable player...
By abobrien in forum Portable VideoReplies: 4Last Post: 9th Aug 2007, 07:36
