I accidentally removed the Canopus DV Codec from my PC and upon retrying to install it, I'm given a "The Win16 Subsystem was unable to enter Protected Mode, DOSX.EXE must be in your AUTOEXEC.NT and present in your PATH" message.
What the...?
If there's no fix to this, what about this... How can I capture with Ulead MovieFactory 2 and not have to then reencode the DV to type 2 so I can use the file in VirtualDub?
Originally Posted by filmjax
Becuase of the mass data-stream you aren't advised to use DV at 16bit systems like DOS.
If you are unable to do the re-installation of the Canopus software, I gues you should do an entire re-installation of your OS.
Screwed over by a CODEC install
By AveEye in forum Newbie / General discussionsReplies: 1Last Post: 27th Jan 2012, 04:34 -
Allowed Win2k to install driver for Canopus ADVC110
By CuriousYellow in forum Capturing and VCRReplies: 4Last Post: 9th May 2009, 14:34 -
Did I install the wrong mp3 codec?
By Havoc X in forum Software PlayingReplies: 3Last Post: 2nd Jun 2008, 21:22 -
Missing Codec(s) ... How to find/install/use?
By CaptainChaos in forum Video ConversionReplies: 7Last Post: 18th Oct 2007, 02:47 -
Should I install Canopus Codec?
By tranbuimd in forum Video ConversionReplies: 4Last Post: 26th Jun 2007, 18:01
