This seems to be the last thing to master.
I have used CCE to make GREAT DVD rips to SVCD...can't tell the differance.
Yet I capture DV footage to disk and use similar settings to convert to SVCD and I see tiny little blocks whenever there is movement in the video.....I have tried both CCE (5 pass average 2500M/sec max 3400 min 500) and still see blocks....cce is noticably better than tmpge 2 pass same bit rate settings.
So why can I get perfect DVD-SVCD and not DV?...DV source quality is sposed to be excellant.
One thing I would like to try is flattening the colour....I notice that the DV codecs (I am using AVI_IO and main concept codec to capture but have tryed Premier as well) capture in Millions of colours...I wonder if this means its is 32 bit colour?...anyone know?...I wonder if I converted the colour to say 16 bit (which u would never be able to see the difference) if I would get reduced macro blocks? Anyone know how to flatten colour?
Just a thought....very frustrating to see such great DVD rips but not be able to get to the same quality with DV....
anyway have any thoughts be greatly appreciated
Hmm... i´m facing the same problems, it seems. I wanted to use SVCDs to archive my digital video material that has been taking up a lot of tapes so far. I tried every reasonable settings with TMPEnc but as soon as there´s a slight touch of movement in the movie, the video gets blocky. Another pitfall for me is that most of the material i recorded is about moving targets, so much of the environment is moving too.
Just wanted to revive this....still not made any progess...still get bazillions of tiny blocks on movement even with high bit rates...
Same problem. I've tried everything I know to do. It's almost very good quality but comes out to be OK. Regular VCD is almost as good.
Krs2pher
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
LAME 32-bit or 64-bit in EAC under Windows 7 64-bit?
By flashandpan007 in forum AudioReplies: 1Last Post: 12th Apr 2011, 10:40 -
Colour Conversion problems with Avisynth
By wiseant in forum Video ConversionReplies: 6Last Post: 16th Mar 2011, 12:40 -
Problems with subtitle font and colour
By skp61 in forum SubtitleReplies: 5Last Post: 29th May 2009, 20:29 -
FFDShow Big Colour Problems
By Endemoniada in forum Software PlayingReplies: 3Last Post: 28th Feb 2008, 23:19 -
Deep Colour/xvYCC colour/x.v.colour confused consumer
By ArthurDaley in forum DVB / IPTVReplies: 10Last Post: 9th May 2007, 19:10
