  1. Ok my problem is when im trying to write from .iso ... dvd 5 layer movie i get a Disk I/O error , and i have tried force aspi , and adaptec aspi layers, and even the default settings ... amazingly enough i did however get one dvd to work... this dvd-r was a ( Memorex DVD-R ) so i figured that any dvd-r would work so i went out and bought ( Memorex DVD-R Version 2.0 ) and have had problems ever since... i have got the program to burn but then about half way through the burn all i get is fail!!! And ruin my damn dvd-r
    Any help would be greatly appreciated if you have had this error and been able to overcome the problem... please let me know asap!! thanks
    I ripped the dvd-5 layer movie with dvd-decryptor and it worked fine... just trying to burn with dvd-r version 2.0 discs ( Memorex )
    shall i try older dvd-r discs... any comments !!!
    Thank you for your time in reading this.
    Syphon
  2. What drive to you have, what speed are you trying to burn, and when you say the burn fails exactly what error message do you get.
    Nov 2000
    Canada
    Why are you using Memorex discs? They are classed as some of the worst DVD-Rs you can buy. Try again with some better media like Pioneer, Verbatim or Fuji. If you are on a budget, try some Ritek discs. Bad media is one of the biggest problems with owning a DVD recorder/burner...
  4. So the media huh .... all i know for the first post was .. it said Disk I/O Error and lots of garbled numbers addresses and such ill try to post the image or screenshot for people to see...
    as for dvd burner it was a Cendyne aka.. ( Pioneer DVR-105 ) and burn speed was 1x
  5. hi,as far as i know that error [Disk I/O Error] is an input output error,i would guess there might be a communication problem between the hard drive and dvd rewriter.
