Ok i have this tutorial that allows you to convert your xvid films to 25fps, i have done everything that the tutorial has said. But when i encoded it to Mpeg 2(DVD) with Tmpgenc the sound is out of sync!? whats going on here i thought! then i looked at the timing for the audio and video file, the Video file said 1:12:04.680 and the Sound file said that it was 01:12:04.641 could this be the reason to why the audio isnt in sync?!
Thanks for any help given![]()
Smokey :D
How bad is it going out of sync? If it is a small sync problem, then try using Goldwave to stretch or shrrink the audio. If the sync gap is large, then you might be looking at an .ac3 problem. You might have to play around with your audio file to get it in sync.
Its only out of sync a little bit! how do i stretch in goldwave? i had to use the timewarp to try and get the video and audio the same but it never worked?!
thanks for the reply
Smokey :D -
In Goldwave open your audio file. Then under Effects choose Time Warp. Choose time, then enter the exact time of your video. Use the resulting .wav file to remux your audio and video.
I have a feeling that since your audio and video time are so close, that this might not make much difference, but try it first. I also wonder, did you change the the framerate of the audio in Besweet? If not, then that would be a good place to start.
