    Jan 2003
    New York
    I have a set of VCDs that I have copied many times and am trying to make another copy of the set but for some reason I can't copy some of the discs. I am using NERO and have tried differant speeds to copy it but it keeps saying "Could not perfoem start of Disc-At-Once". I have tried it on my computer at school and on my mothers at home and they both do the same thing some of them copy and the same ones don't. Anyone have any ideas?
    "My first computer cost $2,400, had no hard drive, 16K of memory, a 120KB 5" floppy disk, [and] a green monitor"
    Gritz-dvdrhelp.com
    Mar 2001
    Antwerp - Belgium (Europe
    Try to create a disk-image first.
    Then burn that image (afterwards) to disk.
    Properly there's something wrong with the performance of your system so on-the-fly DAO copy isn't possible. When you first create cd-image of the cd you want to 'clone' to disk and afterwards burn that image to disk (at DAO) you shouldn't have any problem.
    But if you do, then check your burner - maybe its defected?
