when i try to decode a divx movie the program gives the following problem:
can't load "P3package.dll"
what's wrong?
thanks for your help.
Dennis
Need more information. What are you 'decoding' with and what are you trying to do?
Either re-install TMPG Enc' or D/L the driver from here
http://www.dynamiclink.nl/Dll-Files-P.html
thanks for your reply,
i tried to copy on vcd a dvd rip from internet
i downloaded it in divx and i want to convert it to mpeg vcd
thanks Dennis -
Did you try and D/L the DLL from the link I posted
D/L it and then unzip it into the folder that you have your encoder. -
thanks ABAB.
it worked, i had to download dll 3&4 but know i'm decoding we wil see if it workes.
all the movies i download are more than 80 minutes so i can't put them on a cd, how do i splitt the movies?
or how can i get one movie on 1 cdr.
thanks Dennis -
Browse the AVI to VCD guides found under HOW TO/CONVERT, and 99% of your questions will be answered, and pretty soon you'll be able to put "Video Converting Wizard" on your card.
/Mats
MPEG-2 TS PAT header decoding problem
By jeromedroz in forum ProgrammingReplies: 21Last Post: 27th Jan 2016, 04:02 -
Virtualdub and AVC file (decoding problem)
By EdoScario90 in forum Video ConversionReplies: 4Last Post: 12th Dec 2010, 11:33 -
Problem in decoding audio in WMV3 video file
By sapfeer in forum Software PlayingReplies: 6Last Post: 16th Mar 2010, 14:09 -
DVD to DivX - Chapter Decoding Problem
By Nuin in forum DVD RippingReplies: 0Last Post: 25th Mar 2009, 17:56
