I am having serious problems trying to burn a movie from a dvd-r disc to a dvd+r disc. I always get a "not enough space" warning that pops up no matter what authoring program I use. The DVD-r disc that contains the movie is the same size that my dvd+r disc is. The movie only takes up 4.25 GB on the DVD-r disc so I am not sure what the issue is. The blank media I am using does not contain any other data and they hold up to 4.7 GB.
When I play the dvd-r disc on my Apex, it says "SVID" on the top portion of the screen. I have never heard of this format and I don't know if this is my problem. Could someone help me? Thanks in a advance!
i had a similar problem with a film i used nero to do a 1 to 1 copy. i use writer (sony) to read and write when the reading was finish it told me insert a blank but when i did it told me not enough space but the film was only about 3gb. So i use decrypter to rip the entire film (all Files) to a folder on hard drive then i used nero to burn and that worked for me.
Dont know if it will work for you but its worth a try
After burning, DVD disc was changed to CD
By coody in forum ComputerReplies: 0Last Post: 22nd Sep 2009, 22:16 -
dvd Burner crapping out while burning DL disc, need help
By mazinz in forum DVD RippingReplies: 7Last Post: 21st Jan 2009, 18:38 -
Empty DVD Disc with a movie on it ???
By macbuz in forum MacReplies: 8Last Post: 8th Jan 2009, 13:42 -
LG DVD-R 4.7GB/ 120 mins. 1-8X DVD Disc with 2:28.52 movie
By Gerald Sr. in forum Authoring (DVD)Replies: 4Last Post: 12th Nov 2007, 17:09 -
Burning DVD's Problem Faulty Disc's ???
By Daftwood in forum MediaReplies: 4Last Post: 1st Jul 2007, 17:44
