Hi,
I have burnt many VCD onto CD-RW and played it many times on my DVD player, and playback is perfect. However when I burn the same file in the same way to a CD-R it doesn't play. Now every user who has reported on my DVD player (JVC XV-S42) on the DVD Players page has said the unit does support both CD-R and CD-RW media, and the instruction book also says this. The CD-R plays fine on my PC.
Why can't my DVD player play the disk then. Does the DVD player not support it (I would have thought that if it can support CD-RW CD-R should be easy though). Or am I just using a crap brand of disks (I have tried both Imation and Sony disks, and I used a maxell CD-RW). Or am I burning the CD-R the wrong way (I use VCDEasy, and just add the one file to the list, no PBC, select Simulate, and click Go.
Please help,
Matt
You selected "Simulate" and not "Burn", or both?
Hello. -
I think I've solved this problem. I tried burning on a third brand of CD-R media: Ridata. The VCD played fine on my DVD player. I'll make sure I stick to Ridata disks in the future!
Thanks for your help,
Matt
DVDs won't play on anything
By A Traveller in forum Software PlayingReplies: 3Last Post: 4th Jan 2008, 16:20 -
DVD Won't Play
By gumdoc in forum Newbie / General discussionsReplies: 3Last Post: 28th Dec 2007, 20:10 -
DVD won't play
By Golgo13 in forum Newbie / General discussionsReplies: 4Last Post: 19th Sep 2007, 16:40 -
one particular DVD won't play on my PC
By moe_b_disc in forum Newbie / General discussionsReplies: 3Last Post: 2nd Sep 2007, 06:20 -
'Some' disks won't play...
By Anonymous4374945 in forum Newbie / General discussionsReplies: 7Last Post: 30th May 2007, 17:14
