  1. I'm converting a DivX avi to SVCD. Is there a way to slightly "blur" the picture during conversion thus making the pixelation in the original avi less noticeable in the final mpg?
  2. Member MpegEncoder's Avatar
    Dec 2002
    Wish I was on Catalina Is
    What encoder are you using?
    TMPGEnc has an option to "Soften Block Noise"
    Mar 2002
    United States of America
    You could use the "Noise Reduction" filter. :P
  4. Member MpegEncoder's Avatar
    Dec 2002
    If pixelation is the problem, the "Soften Block Noise" will probably work better than "Noise Reduction".
