Hi everyone,
i was just wondering what the mojaor differences were between CCE v2.50 and CCE v2.66. Are there any major differences between the two? which version is more compatable with DVD2SVCD??
Anywa other comments on the above software would be most welcome, thx a lot everyone
dvd2svcd recommends using 2.50 and not 2.66...says there is compatiblity issues. i use 2.5 and it works flawlessly with dvd2svcd....so i say why change..
there is a new much more affordable version of CCE coming out. That would be the one to purchase as it is very cheap (about $58 ).
and it does xpass vbr mpeg2.Corned beef is now made to a higher standard than at any time in history.
2.66 has some added features over 2.5. The most important upgrade is just that the encoding algorithm has been tweaked so it should be able to provide better quality, but personally I don't really see any difference. 2.66 does have some nice new filters though. Also it has a built in 3:2 pulldown feature so you no longer have to run your ntscfilm encoded material through pulldown.exe afterwards, but that only takes about 5 secs anyway.
Also I believe the audio encoding has been enhanced, this was done even in some versions between 2.5 and 2.66. But few people use CCE for audio anyways so this is kind of a non-issue.
There is a comparison chart on cinema craft's homepage if you want the technical specs for each package. Personally I have just stuck with 2.5 because it has never failed me yet.
CCE vs ConvertXtoDVD
By ranosb in forum Video ConversionReplies: 23Last Post: 5th May 2009, 20:14 -
CCE OPV
By name123 in forum Newbie / General discussionsReplies: 2Last Post: 7th Jan 2008, 12:03 -
best software for cce sp
By zookeeper525 in forum DVD RippingReplies: 12Last Post: 25th Dec 2007, 14:41 -
CCE-SP2
By Belfour in forum DVD RippingReplies: 10Last Post: 29th Sep 2007, 19:47 -
CCE VS DivX
By SteveF22 in forum Authoring (DVD)Replies: 9Last Post: 25th Aug 2007, 20:13
