  1. Member videocheez's Avatar
    Jan 2003
    I see these terms intermixed and I cant figure out the difference. Do you know of a guide that explains the differences.?
    Thanks in advance,
    This is so much fun!
    Apr 2002
    The State of Frustration
    The Glossary here has the definitions. But to make a long story short, DivX is a kind of AVI.
    Hello.
  3. DivX is an AVI file encoded using the DivX codec. You need this codec installing on you system to play the file.
