I have a Pioneer A03, encoded in TMPGenc, authored in Maestro. I am in need of a good burning program. Running Win XP Pro
1. Maestro will not recognize the drive.
2. Neither will Gear Pro DVD
3. Prassi will but I do not trust it
4. Trying to stay away from Nero as I have heard many contradictions over its modes for burning DVDs and compatibility.
What program can I use that will give me the best compatibility/compliancy for making a DVD from a VIDEO_TS and AUDIO_TS? Heard the best about Gear Pro but wont recognize drive, something about interface. Anyways any other programs that are on par with Gear Pro?
Let me guess, nobody burns DVDs. Or maybe you all use nero. Ive heard hundreds of people complain that nero doesnt work. Well what does work.
got the 105 drive, i use recordmax now, used nero in
past with v 55917/5590,like to burn with ic software... -
I use Ulead Video Studio to edit my videos and Dazzle DVD Complete to set up menus and chapters and to burn the final product. _ I have the Pioneer A04 burner and have not had any problems - the DVDs work in every player I have tried and look great. I have used several brands of DVD-R media all with great success.
I have not tried copying any commercial DVDs so I cannot comment on that. I use mine primarily for transferring home video. -
I use Ulead dvd movie factory version 1. I have the pioneer 104 dvd burner and have never had a problem. I use it for authoring and burning.
how good is Recordmax now? Has anybody had any issues with compliance or compatibiltiy? Is it easy to use?Originally Posted by musher70
another thing, what is ic software? -
"Changes From Nero 5.5.10.0 to 5.5.10.7
Bug Fixes :
Fixed the bug which produced incompatible Video-DVDs not playable on some DVD-players"
has anybody had any problems with nero 55107b? It seems like they may have fixed the error according the the version info
VIDEO TS Burning Program
By videocheez in forum Authoring (DVD)Replies: 2Last Post: 30th Jun 2009, 06:55 -
Burning program options
By efiste2 in forum DVD RippingReplies: 4Last Post: 14th Jul 2008, 19:44 -
Install only selected program from a bundled suite software
By ks47 in forum ComputerReplies: 6Last Post: 16th Apr 2008, 10:39 -
Need program/software for Vista
By Me-Hostage in forum Authoring (DVD)Replies: 2Last Post: 5th Sep 2007, 06:16 -
Install only one program from a video editing software
By ks47 in forum ComputerReplies: 2Last Post: 29th Aug 2007, 01:31
