I am able to convert the .m2v file into .mpg easily enough. However when I do it always leaves a small boarder on the edges on the right and left-hand side, however it doesn't do it at the top and bottom.
I have tried changing the different ratios, boarders, etc. but I am still not able to converted it so it turns completely fullscreen. Can someone instruct me so I am able to convert the files without having the boarder on the sides. Thank you.
Some more information is required.
What is the source of the mpeg2 video (.M2V) files?
What format exactly are you converting them to? Mpeg1/2, resolution/spec?
Is there an audio file?
What are you doing with the resulting mpg files? -
Don't worry, the borders won't show up on your T.V.
:P
Overscan:
The area at the edges of a television tube that is covered to hide possible video distortion. Overscan typically covers about 4 or 5 percent of the picture.
Hope That Helps!!!
:P
Problems converting rm files
By kcahill in forum ffmpegX general discussionReplies: 23Last Post: 7th Dec 2008, 20:03 -
problems converting rmvb files
By Kavelian in forum ffmpegX general discussionReplies: 13Last Post: 15th Jun 2008, 12:58 -
Converting .rmvb files problems
By Gilberts in forum ffmpegX general discussionReplies: 7Last Post: 14th Nov 2007, 18:17 -
Problems while converting ts files
By vertical in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jun 2007, 15:01 -
problems Muxing M2V and Aiff files to MPEG2
By bbaddorf in forum ffmpegX general discussionReplies: 4Last Post: 18th Jun 2007, 16:14
