  1. Hi, I just bought a CD-burner the other day, so I'm real new with everything. Luckily, today I figured out how to work TMPGenc, and Nero 5.5. I even burned an episode of Cowboy Bebop on VCD. After watching, I went to burn an episode of Tenchi, but it was in RM format. Unfortunately, I dont think TMPGenc supports RM format.
    I have looked on this forum for an answer, and I did hear about something called Tinra. I have not downloaded it yet, but I will soon. I was just wondering if I had any other options. Thanks.
    Jul 2001
    Maryland
    you can use hypercam to record your desktop as you play the episode and create a sound feedback loop.
    it's easier to look for techi in mpeg of divx.
    real media is very very hard to convert and you get crap.
