I have 3 movies I'd like to put on one disc.. My question is, how would DVD2One react if each movie has different aspect ratios (4:3 and 16:9).. Also, what if the audio for each movie is on different tracks?? (For example before when I'd rip to SVCD, and use DVD2AVI, I'd usually select TRACK1 for the audio, but one movie I have it's on TRACK2)
It really is simple but I guess it'll take some additional work... Since the movie has different aspect rations and audio tracks. And since you want to use DVD2ONE... I would do this.
Rip the vobs of each movie into 3 different folders. Pull out your calculator and crunch numbers to see how big each movie has to be (4.3gigs). Then create IFO files for each movie... Run DVD2ONE lastest version --- Reserved the space... And you'll end up with 3 movies that should be around 4.3gigs...
Now the fun stuff starts... I don't think IFOEdit will make correct IFO files for the 3 movies. So I would demux the DVD2ONE vobs into m2v and ac3 files and use Maestro to author... Hope that helps...
dhluke -
Plus you would also see some very poor quality video during playback if you were able to get more than one full movie on a disc
I have put 2 movies on 1 disc using dvd2one and ifoedit. The movies were night of the living dead (4:3) and the thing (widescreen). I have no problems playing them with different aspect ratios. The quality is OK, but remember both movies are around 90 mins. I wrote an ifo using ifoedit, however I ran it through dvd2one after that so it would create a correct ifo.
Multiple DVD on BD disc?
By shadow85 in forum Authoring (Blu-ray)Replies: 6Last Post: 27th Oct 2011, 20:07 -
How to copy DVD 9 to 5 with menu & extras using DVD2ONE.
By BarryHL in forum User guidesReplies: 145Last Post: 24th Mar 2011, 08:36 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 07:26 -
Disc copy of a dual layer disc
By kingjames in forum Newbie / General discussionsReplies: 3Last Post: 1st Oct 2007, 13:52 -
multiple vids on one dvd disc
By johnnyboy1908 in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2007, 02:34
