I am converting my captured avi to cvd. When I try encode, TMPGEnc just closes without any error messeges. It doesn't do this for every captured file, just certain random ones. This is why I believe that this is a software issue. Anybody can help? I already checked my hd, it has enough space.
Has it always done this, or is it recently? If it is recent, suggest you remove then reinstall it.
Hello. -
Take a look at the Options Menu>Environment Settings.
The VFAPI Plug-in tab shows priority of each plug-in - right click the AVI2(OpenDML) plug-in and increase it's priority by one (maybe two if one doesn't work).
Then try the encode again.
Martin. -
This always happens to me if I convert frame rates without converting frame rates (i.e. the Do No Frame Rate Conversion option is on), and have audio. I always do it now without the audio, and remux the audio later as it needs fixing in a different program anyway.
Dave
CamStudio suddenly closes
By terrypin in forum Newbie / General discussionsReplies: 1Last Post: 21st Feb 2010, 08:40 -
FAVSC Error Messages...in ImgBurn??
By sandman423 in forum Newbie / General discussionsReplies: 3Last Post: 9th Aug 2008, 08:06 -
SV2000 timer error messages
By Mr. Blue Sky in forum DVD & Blu-ray RecordersReplies: 8Last Post: 26th Aug 2007, 07:15 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41 -
TMPGenc just closes - no error msg - no rhyme or reason! Help please.
By brightsun23 in forum Video ConversionReplies: 3Last Post: 15th Jun 2007, 11:42
