Following some hints in the CAPTURE forum, I've been experimenting with capturing my 8mm tapes at different resolutions. I use the huffy codec. When I play the AVI in WMP, the display resolution is the same as the capture resolution. That is, capture at 320x240 plays at the NTSC 4:3 ratio.Capture at 356x480 plays at .771 ratio. I'd like to make the 356x480 display at 4:3. (Studio 8 does this, but the window is too small to judge quality.)
Any players able to do this?
I think Zoom Player will do what you are looking for. I use Zoom Player 3 and it will let you force a certain aspect ratio on the fly.
Good Luck,
Prospero -
Thanks. I just downloaded it and will try later tonight!
Edit: Yes! ZoomPlayer does allow the aspect ratio to be forced to 4:3.
Just what I needed.
[Avidemux] Aspect Ratio vs Playback
By Shadarr in forum EditingReplies: 9Last Post: 12th Aug 2009, 08:54 -
Aspect Ratio Playback Problem
By dawson54 in forum Newbie / General discussionsReplies: 2Last Post: 6th May 2008, 23:01 -
Forcing Aspect Ratio during playback
By hcowan in forum Authoring (DVD)Replies: 1Last Post: 24th Apr 2008, 15:02 -
ffdshow playback and aspect ratio
By greenbag in forum Video ConversionReplies: 6Last Post: 12th Oct 2007, 02:18 -
Aspect ratio keeps switching during playback
By Daffyd39 in forum Newbie / General discussionsReplies: 12Last Post: 29th Aug 2007, 12:40
