I have made SVCD using DVD2SVCD and Nero. I have a Toshiba SD-210E Player. I obtain perfect results using CD-RW but wit CD-R i get a lot of freezing reading the SVCD on my player. I tried reducing the burning speed with the same results. Is it the fault of the media I am using (Memorex)?? Can anybody suggest a better media or other solutions??
have you looked at the DVD Players list <========== at the side menu? Look up your player can it actually play CD-R's according to the list? My SONY 535 player can only play CD-RW and not CD-R's... so I bought a DVD writer... better quality and not problem playing them on my DVD player.
I've just had exactly the same problem, and I have solved it by burning onto a different media. Imation and Sony didn't work but Ridata works.
Try burning to few different brands, it solved the problem for me.
Matt
Which Media player reads timecode?
By sp_key in forum Software PlayingReplies: 7Last Post: 20th Dec 2012, 16:22 -
Same copied Blu Ray only reads sometimes in player, all the time with PS3.
By sevensees in forum Blu-ray RippingReplies: 8Last Post: 5th Mar 2012, 11:57 -
Blu-Ray player that reads MP3's
By Megaman00001 in forum AudioReplies: 1Last Post: 21st Nov 2010, 07:55 -
dvd player reads "no disk"
By VINCIBLE in forum DVD & Blu-ray PlayersReplies: 7Last Post: 24th Jul 2008, 13:56 -
DVD recorder LG DR175B won't read burned DVD but common DVD Player reads it
By Mycow in forum Newbie / General discussionsReplies: 0Last Post: 12th Aug 2007, 18:59
:P
