    Jan 2003
    I'm thinking of buying the Toshiba SD-R5002 DVD writer for $180 from newegg.com. My standalone is a Panasonic RV32 (I absolutely love) which says it will only play DVD-Rs authored on Panasonic DVD writers. Has anyone had any luck with this player playing DVD-Rs authored on a Toshiba? I don't want to buy it and then find out the panasonic won't play them. Which media is known to work for this player? Thanks for any info.
    Tim
  2. I have one and used the SONY DRU500a along with Record Now DX, everything works ok in it so far.
    Jan 2003
    Thanks for the quick reply. Does the zoom button still work on DVDrs?
    Tim
  4. It works on mine, i make my dvd's with only the essentials using dvd2one angle 1, 6chn ac3, and movie, and the zoom works as it supposed to. no dvd audio tho
