Help
I am a beginner with this app
I am using this app to make a DVD all has gone well up to trying to make a slideshow.
I can get all the images in the side bar and the icons at the bottom have the little overlay on it to tell you that it has multi titles attached to it.
I have two menu's One for the main Video ( its a wedding ) and the other video on this menu is the night time party.
On the second menu I have tried to create my slide show.. with two buttons on the menu linked to the two icons at the bottom of the page, all the images show in the panel bar on the right.... but when I go to view my whole project everything works except none of my images show when I click on the button thats linked to them.... it plays a black screen for 7-8 seconds then stops..
I cant view any images when I click on edit from the icon.... when I press play in the edit window I get just a black screen, then it jumps back to the button image thats linked to it.
any help or ideas or am I just plain thick and totally got it wrong...
MJ.![]()
You may want to try the following:
Click on each one of the two buttons that are linked to the pictures at the bottom. Uncheck the link box on the left. This will break the link between the buttons and the icons at the bottom. Then try to relink. But this time instead of dragging the icons from the bottom of the screen, drag the first (top) picture from the right side of the screen. This way you are making sure that each bottun is linked to the first picture in each of the slide shows. Hope this would work for you. Good luck. -
falberni
Thanks bud I have tried that but still no good, What I have found out is, that my images are set to show for 8 secs, but if I drag the cue bar to 8 secs the next image shows, and then to 16 the next one shows and so on untill I drag it right to the end.
They all show this way but when I click on the play button they don't show..... do you have to render and burn the dvd and then it will work.
I can't get it to show the images any other way but this...
MJ..
Does anybody have Ulead DVD Workshop SE 1.21?
By OS_Man in forum Authoring (DVD)Replies: 5Last Post: 21st Sep 2010, 02:04 -
Ulead DVD Workshop 2 with Vista?
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2008, 02:48 -
Ulead DVD Workshop 2 error
By SEE_Studios in forum Newbie / General discussionsReplies: 21Last Post: 4th Jan 2008, 02:55 -
Video is upside down in DVD Workshop 2
By darkcyber in forum Authoring (DVD)Replies: 12Last Post: 7th Oct 2007, 21:22 -
DVD Workshop 2 on Vista
By jaffacaique in forum Authoring (DVD)Replies: 6Last Post: 22nd Aug 2007, 09:16
