how can i put 2 subtitles on a DVD movie?
another question is:
how can i convert ssa to sup so i can put in IFOedit or Maestro?
In theory, you can do it with IFOEdit. I have failed (but must confess I have not tried hard
You can rip the subtitles with subrip. It can export them in various formats. You can find a nice conversion program in doom9.org that can create your IFOEdit sup file (called sub2sup, if I remember correctly).
Additionally, you can find there also a program that can take .ssa files (ASCII) and render the bitmaps from it.
Another option to create DVDs with selectable subtitles is to use a program like scenarist (very expensive and very user-hostile) that once you learn how to use makes this task as snap. Scanerist allows you to create a DVD as complex as the studio productions. (Most of the studios use Scenarist to author DVDs).The more I learn, the more I come to realize how little it is I know.
AVI to DVD with selectable subtitles
By egooxenos in forum ffmpegX general discussionReplies: 9Last Post: 5th Dec 2009, 02:04 -
Rip a DVD to a MPG file with selectable subtitles
By jjulio1 in forum DVD RippingReplies: 3Last Post: 1st Feb 2008, 01:24 -
How to burn a DVD with TWO (2) selectable set of subtitles?
By DaPuertorican in forum MacReplies: 0Last Post: 22nd Nov 2007, 12:27 -
DVD selectable subtitles
By exekutive in forum ffmpegX general discussionReplies: 6Last Post: 24th Sep 2007, 12:36 -
DVD or AVI -> to MP4 with selectable subtitles
By radium02 in forum DVD RippingReplies: 4Last Post: 6th Sep 2007, 00:55
