i have small two problems, i have recorded some mpeg2 files using a dvb card, so now i would extract the audio track to make some wav files, which suitable program should i use to do it? the other problem is that i would decrease the bit rate of teh mpeg2 files, it's close to 5500kbs, to make some svcd, how can i do it?
thanks in advance for your help, bye!
You can use TMPG to demux the video and audio. Then open the MP2/PCM audi track in HeadAche or Besweet and convert to whatever you want.
5500 Kbps won't work for SVCD. You total maximum limit for Audio+Video is...ummmm...help me out here...2650 Kbps? That is about 2250 for video with enough room for 192 kbps audio and muxing overhead. Check the guides, but you can use TMPG or CCE to re-encode to a lower bitrate ( you will also need the MPEG2 codec to read the file ).To Be, Or, Not To Be, That, Is The Gazorgan Plan
3d questions
By alucard2050 in forum DVB / IPTVReplies: 16Last Post: 21st Aug 2010, 23:01 -
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 15:50 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 18:08 -
Some Yes or No questions
By the_importer in forum Media Center PC / MediaCentersReplies: 22Last Post: 3rd Jul 2008, 18:06 -
Got a new 16:9 TV, have some questions...
By sdsumike619 in forum Video ConversionReplies: 6Last Post: 28th Jul 2007, 14:00
