Not sure where to post this question...
I'm editing some files with Winproducer (I know I can use other editing software but this works best for my particular application - long explanation) when I save the MPEG files I can view them fine but I can't load them into Virtualdub or TMPGEnc. I get the errors :
"MPEG Import Filter: pack synchronization error" from virtual dub
"filename can not open, or unsupported"" from TMPGEnc
Anyone know how I can either fix these MPEG files or fix Winproducer (v2 I believe). I have DivxFix which fixes DivX .avi files real well, something like this but for MPEG's would be great. Thanks.
rhuala
Do all MPG files do that? Cuz i think it's a version and filter problem you got there. Do you have an MPEG2 codec installed? try installing one, and then try importing again.
Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
No all other MPEG files are fine just the ones that Winproducer exports I have problems with...
Fixing corrupted MPEG-1 VCD (freezing issue)
By headless chicken in forum EditingReplies: 11Last Post: 4th Sep 2009, 22:55 -
Fixing Out of Sync Issues with Mp4 files?
By djfreex2 in forum Newbie / General discussionsReplies: 1Last Post: 12th Jul 2009, 13:01 -
Fixing Sandisk V-Mate's MP4 files when interrupted
By Atario in forum Newbie / General discussionsReplies: 2Last Post: 15th Jun 2009, 19:50 -
Reparing or fixing AVI files
By 1234567 in forum EditingReplies: 26Last Post: 16th Feb 2009, 17:53 -
Fixing troublesome mpeg files?
By Hatecrime69 in forum Newbie / General discussionsReplies: 5Last Post: 4th Mar 2008, 16:41
