Hi!
I read somewhere that toast cannot produce good svcd from the .bin/.cue files. In the post the person who said this also said that one should use a burn software called "MMB".
I have downloaded that software, and would like to have a step by step guidense in how to burn with it.
I also think that it is quite strange that 42 produces image files that toast cannot work with, since many mac users use toast.
Please enlighten me!!
Toast 5.2 is just fine, but it's little picky in accepting VideoCD .bin files.
First off, Toast doesn't need .cue files at all.
Secondly, I guess below is why your Toast .bin file is not accepted as VideoCD in Toast:
Toast needs "MPEGAV/yourMovie.dat" folder instead of "MPG2/yourMovie.mpg" folder. I don't know why Toast only accept it in such way, anyway, if you mount the toast image 42 did generate for you (launch Toast -> Utilities menu, choose Mount Disc Image...) you will find out that there is an "MPG2/yourMovie.mpg" folder, right?
If so, you'll need to change this into "MPEGAV/yourMovie.dat" so Toast can accept it as valid VideoCD.
To change the folder/file names, use "SVCD Fixer" or "Gumby". You won't be able to change these manualy, at least not that I know of...
Hope this helps you out.
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 03:48 -
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
m2ts to burn in Toast 11 (MAC) Issue
By Reesche in forum MacReplies: 3Last Post: 27th Sep 2011, 15:55 -
Cant burn Video TS in Toast
By 3lutz3toe in forum MacReplies: 21Last Post: 11th Sep 2009, 17:31 -
How to burn toast file in windows XP?
By yunakokimama in forum Authoring (DVD)Replies: 2Last Post: 12th Dec 2007, 18:01
