HI
I WOULD LIKE TO CHOOSE DIFFERENT VIDEO CHAPTER FROM DIFFERENT DVD AND PUT IN 1 DVD-R, SPECAILLY FOR KARAOKE VIDEO SONG, IN THE SAME WAY LIKE WITH CD-R. IS IT POSSIBLE AND HOW?
PLS HELP.
THANKS
AV
You can use a capture card to capture scenes from a couples of DVDs, then use TMPGenc File-->MPEG tools-->Merge&Cut to link them up as one DVD title only. Burn it. However, the audio (am-thanh) from different DVDs will be diffenrent (to-nho khac-nhau) or distorted
Or...
You can use DVD Decrypter or SmartRipper and uncheck the unwanted chapters and only keep the chapters you want and then use Maestro to author OR you can rename all the vob files and use IFOEdit to make new IFOs...
dhluke
VOB2MPG chapter split - inaccurate?
By Toreadore in forum SVCD2DVD & VOB2MPGReplies: 11Last Post: 16th Dec 2010, 14:43 -
TMPGEnc DVD Author 3 (Chapter Split In two)
By GeorgeD123 in forum Authoring (DVD)Replies: 2Last Post: 13th May 2010, 20:44 -
Split chapter VOB ???
By sabercats in forum Newbie / General discussionsReplies: 2Last Post: 18th Feb 2009, 17:48 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 07:58 -
Procoder split/split by size/media query
By kippard in forum Authoring (DVD)Replies: 7Last Post: 17th Nov 2007, 22:35
