Hi
DvdBackup resulted in a 6.26 GB file that is perfect copy of the dvd. Question is, how does one then burn this! Its too large for my blank dvd-r.
Whats one to do?
You can't burn it. DVDR's only have 4,700,000,000 bytes or 4.37 GB. You have to split it to 2 disks, or re-author and re-encode to a smaller size.
To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I was afraid of that. Dvdbackup is sooo fast. I get this file in about 15 to 20 min! What is the point of this program if you cant burn the files it creates.Originally Posted by Gazorgan
Any suggestions as what program for dvd encoding!???
and then to burn??? -
if you use dvd2one it will shrink the dvd to 4.36 gb and not loose quality it takes approx 25 min to do
i used it and the quality was excelent -
there isn't a mac version of dvd2one, is there? DIVA and forty two both allow you to rip DVD's into lower bit-rate MPEG-2 files that will fit on one DVDOriginally Posted by flt123
It's a 100% backup, so basically it's just copying, that's why it's so fast. If it was a DVD5, then it's a non issue. If it was a little bigger than 4.3 GB, you could edit out some audio tracks you don't need and it may fit. Your particular backup isn't going to fit on 1 DVDR unless you re-encode it (unless it has 6 AC5.1 and 3 DTS audio tracks!)
And yes, I know this is a MAC post. My answer was machine independent :P DVD2ONE is Wintel only, with little if any hope of a MAC version, much less a native OS X version.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
This guide is fricking money, too bad I didn't see this before. ENJOY Galactica
I know i will......
https://www.videohelp.com/forum/viewtopic.php?t=138989&highlight=dvd9+dvd5+guide[/url]
Rip DVD-R's, edit out commercials, burn new DVD Dual Layer...software?
By ruehl84 in forum Authoring (DVD)Replies: 5Last Post: 23rd Feb 2012, 04:06 -
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 13:42 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 05:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 17:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 21:46
