I have been trying to burn SVCD's and I'm not sure what I am doing wrong. Here is the situation:
1) The first set of svcd's I burned using Ulead Video Studio 6 on CD-R Media ( Maxell and AT&T brands) None of these will play in my DVD player which is a Samsung S221. I checked the compatibility list and this player should be able to handle these. The svcd will play on my daughters very cheap APEX player! If I record on a CD RW I can get it to play on the samsung
2) Next I tried rendering the mpg in ulead and buring the CDR with with nero 5.5.10. In this case I can get the menu's to come up but can not select anything to play. It sounds as if the dvd player is still trying to load the cd. Once again... no problem on the Apex player.
By the way, what i am trying to burn are still photos that I ahve put into a slideshow on ulead with transitions and audio. I use the ulead setting sfor creating svcd's, create the mpeg2 file and then burn to cd.
I'm sure I am doing something wrong here but i don't know what.
Is there a test file on this site that I can download and try?
My $53 US Apex plays anything I put in it, while my more expensive (and now returned) $130 multi-disk player wouldn't play 'spec' SVCD's. If it plays in the Apex and your PC, then it's not the burning software.
I think your Samsung sucks, go get another Apex? the 'compatability list' needs to be taken with a grain of salt,a nd you ahve to verify serial numbers are in sequence.To Be, Or, Not To Be, That, Is The Gazorgan Plan
Confused! Confused! Confused! VCR to DVD; major question Toshiba Diomage SV
By CAnn12 in forum Capturing and VCRReplies: 0Last Post: 5th Feb 2011, 11:26 -
Confused about XP cd reformat
By neworldman in forum ComputerReplies: 5Last Post: 22nd Jun 2010, 08:36 -
Soo confused
By slaak in forum Newbie / General discussionsReplies: 9Last Post: 10th Aug 2009, 19:44 -
Confused about 1080p
By gauche in forum Newbie / General discussionsReplies: 4Last Post: 18th Jan 2009, 08:51 -
Ire, still confused.
By aebbeka in forum Capturing and VCRReplies: 15Last Post: 25th Mar 2008, 05:25
