    Jun 2001
    Roy, Utah
    Maybe im really stupid but I cant seem to get the menu's to work with DVD workshop. I make them then when I goto finish it sayssomething like, some menu items have not been linked. Is there manual of something for this somewhere.
  2. If you could be a little more specific, like how many menus you have, how many titles, how you're structuring your menus, etc., maybe you'll get some really good suggestions.
    I'm guessing that you have more than one menu. You have put some tiltes on the second menu. But you have not specified how to get from the first menu to the second menu.
    If that is the case, then drop a frame, or make a text box on the first menu. While the first menu still is in the middle of the screen, drag the second menu from the bottom of the screen and drop it on the frame, or on the text box, that you just created. If you are dropping it on the text box, first click the text box so that it is selected, then drag and drop the second menu onto it. Now your second menu is linked to something on the first menu.
    Hope this helps.
    Jun 2001
    Roy, Utah
    All I need is to know how to link the items, the box is unchecked and grayed out. I will probley feel really dumb when someone tells me because it appears no one has been dumb enough to ask this question before.
  4. If you have more then 1 menu page you need navigation links on each page to link to the other pages.
    With 1 page in the main screen you can drag from the page to be linked to (at the bottom showing all the menu pages) to the text or icon in the main screen to link it. Do this with each menu page in the main screen and save. You won't get the unlinked error message.
    Test your navigation menus in the Finish page in DVDWS before burning or creating your DVD directories.
