Hello everybody!
I was wondering about aspect ratio: My source is a NTSCFilm, 16:9 progressive DVD. When I encode it with Tmpeg in svcd with an aspect ratio of 16:9 the picture quality is bad and it has like a mosaic pixel grid.
Am I doing something wrong or is: source aspect ratio always the target aspect ratio? This is a little confusing for me.
I've learned that when you load your file into Tmpge using the wizard, the only aspect ratio setting I change is on the source range page. Under other settings click advanced then under video arrange method click full screen (keep apsect ratio 2). This makes my svcds look great.
Hope this helps. -
This is what I normally do but with this movie it leaves me with 2 black bars in the mpeg. Bar 1 is from encoding, Bar2 is from the actual movie. So 2 thirds of the screen consist of black bars and only 1 third is left for the actual movie.........
You could try using 'Full Screen', and that will use the whole screen, but if your origional movie is widescreen, then the results tend to look stretched out.
Aspect ratio problems, please help!
By phdutton in forum DVD RippingReplies: 21Last Post: 1st Sep 2011, 08:31 -
By MarioB in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jun 2009, 17:47 -
.vob to .dv, aspect ratio problems
By Groove_Holmes in forum ffmpegX general discussionReplies: 2Last Post: 23rd May 2008, 21:34 -
Aspect Ratio Problems
By Weapon-X in forum EditingReplies: 9Last Post: 9th Mar 2008, 13:38 -
Problems with Aspect Ratio
By qldaussie in forum Video ConversionReplies: 3Last Post: 10th Jan 2008, 12:53
