Results 1 to 13 of 13
  1. I just installed and used for the first time. On the Video track selection page there is a Tab labeled "Preview." When I access the tab, there does not seem to be any functionality. I searched all the Manual and help files, but there does not seem to be any instrctions on how to use Preview. Can anyone help??????
    Jim Petrick
  2. You must have mpeg-2 decoder installed to utilize preview. I suggest PowerDVD or WinDVD both DVD software players.
  3. I currently have Power DVD installed.
    Jim Petrick
  4. I have WinDVD installed and have the same issue, although slightly different- some Titles work and others don't....... not sure what the story is.
  5. Member Super Warrior's Avatar
    I have PowerDVD and the previews work.
    Previews=One of the many valueble features that DVD2One does not have
  6. Mrbass,
    Based on the previous 2/reply's (Power and Win DVD already installed), any other suggestions that might allow Preview to work???
    Really appreciate your contribution to this thread.
    Jim Petrick
  7. not really just be sure you have the latest update for powerdvd installed. Oh yeah one more thing...be sure you don't have some other app (like in your systray) that is allocating the audio. Seems like Instant Copy wants exclusive access to the audio.
  8. Member Nolonemo's Avatar
    Los Angeles
    I have powerdvd and preview didn't work on Iron Monkey (ripped). Maybe this is a disk-specific issue? Or does it work on disks but not rips?
  9. just sounds like another bug, have to wait for updates
  10. You may need to lower your screen resolution to get it to preview. I had to drop down to 1024x768 to get the preview to work. In my case it was an issue with my Matrox G550 video card. Anyway, give it a try. I was also having problems with IfoEdit preview not working and changing the screen resolution fixed both problems for me.
  11. A couple of thigs I have noticed on the preview. 1. the ones that will not preview most of the time are the extra still pics on the dvd. 2 doesn't always work if you are writing drictly to dvd. but does if writing to the hard drive as a disk image. Now they just need to put a little slide bar so you can ff thru the preview..
  12. yes, i noticed the same thing, sometimes when authoring,
    no preview function at all, but who cares just as long as
    it completes...
  13. Member Nolonemo's Avatar
    Los Angeles
    Yeah, my method was to reduce the quality on everything but the main film to as low as possible to max the quality on the main title, so I didn't really care. If there was one particular extra I wanted to preserve quality on, I guess the preview would be nice in order to figure out which one it was.
