I can only burn Ritek 4X media at 2X, tried RecordNow DX(came with drive) and DVD Decrypter. Any experiences?? this drive is supposed to be 4X straight out of the box, and ADVDinfo says the disks are Ritek 4X.
Results 1 to 30 of 56
I only have the Ritek media, and are you using a DRU 500 AX, not just an A with upgraded firmware.
Any other AX users out there??? -
Well my Sony DRU500A worked flawlessly on any brand DVD-R 4x media until I updated it to the 1.0g firmware, now it only records at 2x. Anyone have a link to the orignal firmware so I can go back to what worked?
I wonder if "approved" 4X media would work on the AX, I will have to try some Pioneer media, but its expensive. There are also no firmware upgrades for the AX yet, not that I would be keen to try that.
Any AX experiences?? -
Originally Posted by Bob W
Well, I haven't yet find ANY 4x certified DVD writable media so I can't say if it is a problem with the new firmware.....
A. -
Originally Posted by artemio
I'm using a Sony DRU500A with 1.0g firmware and it burns RiTEK 4X media at 4X just fine.
If you have been following the progress of the Sony drive you know that many things effect the drives performance. The biggest and least known thing being how the drive is connected to your computer. If connected as a UDMA device instead of ATAPI it will not write at 4x speed. You may need to reconfigure how your drive is connected to your computer to burn at 4x. I can write at 4x speed successfully with firmware 1.0g.
Originally Posted by zeppsstteerr
A. -
I had similar problems writing 4x dvdr @ 4x. But after installing the px engine update from www.prassieurope.com it has worked ever since @ 4x.
I also found firmware 1.0f much better than 1.0g. -
And this is for the 500-AX, not a 500-A with upgrade firmware.
any info appreciated.
- housepig -
Most of you are talking about the 500A with upgraded firmware, I have a 500AX, firmware 2.0c (from Nero), and there are no updates. Windows XP recognises the drive as DMA mode 2, same as the DVD ROM , and the 500AX is the master. I tried changing the mode to PIO only and it made no difference. RecordNow DX that came with the drive is the latest, its update manager can't find anything new.
All the burning software I tried recognises the 4X media. Just wont burn at that speed. -
If you can't e-mail me at john@cking52.freeserve.co.uk and I will send it to you.
I use dvddecryptor to create an iso image of the dvd, them use recordnow max 4.5 to burn the image @ 4x.
If you dont have recordnow max lmk and I will tell you were to get it. -
http://www.sonydru500a.com/Pinnacle Studio 8 and DV home video editing (ver.9 already home) -
My SONY DRU500AX also has a problem writing at 4X with Ritek media. I lost two blank disks last night that costed me $4. It said it burnt at 4X, but I noticed that it was very slow and failed at 7%. The 2X burns like champ. I'm not sure whether it's the media or the drive. I bought the drive 10 days ago and it works flawlessly with 2X DVD-R and 2.4X DVD+R.
VCDLover -
Originally Posted by vcdlover
SOLUTION WAS ON MINE:
Use firmware 1.0f and upgrade your px engine from http://www.prassieurope.com/
This works a dream on my 500a 4x Ritek dvdr's burn @ 4x flawlessly. -
My DRU500AX already has 2.0c. What will the px do to improve the writing speed?
vcdlover -
So if I burn a disc +R or +RW @2.4x and it takes about 25 minutes for a full 4.3GB movie, then how long is it taking all of you that claim to burn at 4x?
Just wondering if the cost is worth the time savings?
Doesn't anyone else have two computers or something else they can do while they burn a disc? Just because my Ferrari does 180MPH doesn't mean it has to all the time Apples to Oranges, I know, but is it really that important? My DRU-500A with firmware F burns at 2x for -r, 1x for -rw media and 2.4 for +r+rw media, so far with Memorex, Maxell, Sony, Optodisc, HP and Accu for both formats where applicable. Good enough for me, I've better things to worry about. You guys are lucky that burning speed is all you've got to worry about.
And as pb pointed out, the AX firmware starts differently than the A.
Burn on, dudes.... -
I would like to know if the PX engine update will help, but its dated Nov last year and my 4.6 ver of RecordNow DX says it is up to date for all the veratis components.
I also agree that 2X and 2.4X is good enough, but the Ritek media were a good price, and the drive is supposed to be able to do it. However, I have not had one coaster yet, even the 4X Riteks burned OK at 2X.
As I said, I will try some approved media, or if anyone with a 500AX can tell me if they have burnt at 4X. -
That PX engine update is good news for A04 and A05 owners that wish to continue using PRASSI with these drives, but the update dosn't include the DRU-500.
It also handles other newer DVD burners...
For my experience, I will say I have burned the RITEK 4x at 4x in my FIREWIRE ENCLOSED drive.
I bought the 500a and mounted it in an ADS PYRO encloseure.
So Far it the only media that I've seen that does 4x
I didn't flash my drive and it came with firmware f -
yeh i found that too, friggin thing would say burning at 4x in the sony
but its taking 30mins (2x obviously). How do you go back to 1.0f from 1.0g ? -
The Px Engine update provides product updates, fixes, and new CD and DVD recorder support. Use this download to update these products.
RecordNow, RecordNow DX, & RecordNow Max
MyCD & MyCD Pro
PrimoCD & PrimoCD Plus, PrimoCD Pro8, PrimoCD Pro16, PrimoCD Pro64 & PrimoDVD
Click'N Burn Plus & Click'N Burn Pro
SonicBurn, CD Extreme, Spressa Play & Record
On my 500a with 1.0f occasionally 1in5 4x dvdr's would burn @ 2x. So I tried 1.0g. On 1.0g all my 4x dvdr's burned @ 2x, so I downgraded to 1.0f. Then updated the px engine, I have now burned at least 250 4x dvdr's all @ 4x without any coasters at all. To downgrade from 1.0g to 1.0f, just download 1.0f and install the same way as you did when you upgraded to 1.0g. -
I tried the PX update and it made no difference. The DRU 500AX has different firmware, starting at 2.0C. I will try another brand of 4X media if I can get hold of it.
I'm a bit lost now....I have the same prob with Record NowMax 4.5 It say it's burning at 4x but it only burns at 2x....I have the 1.0f firmware installed. Help Please
Originally Posted by Wookie
No have got that unchecked...its the burn time that takes about 30 mins...... I'll try the Pxe Enginr update and post results.... they also only burn at 2x with DVD Decrypter...but at least with Record Now it said 4X but burned at 2X
Can you think that SONY could DISABLE RITEK 4x writing because media isnīt good enough to support it? If in a more advanced firmware version 4x is disabled, probably itīs because media, in tests returned bad results.
I had the same experience with some line of Intenso media - in the first firmware they could write at 2x (but some pieces, at 27%, gave errors AND some "sucessful writing" when played gave errors!), in the next version of firmware they were only written at 1x but no erros made!
I have DRU500A with 1.0g and I am very pleased with it!
Differences between DRU500A / AX? Besides the box... I canīt find any... 8)
sony dvd rw dru-190a problem
By videodude1966 in forum DVD & Blu-ray WritersReplies: 2Last Post: 17th Apr 2010, 03:53 -
/Sony DRU-190A problem
By Quadzilla in forum DVD & Blu-ray WritersReplies: 22Last Post: 7th May 2009, 14:10 -
Sony DRU 800A Problems burning??
By khronos000 in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2007, 17:40 -
Sony DRU-810A question...
By bamabluebird in forum DVD & Blu-ray WritersReplies: 4Last Post: 10th Jul 2007, 10:21 -
Sony DVD RW DRU-830A
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 08:41
