I have an avi that has a timer counting down in the top right corner. Is there any way to remove it entirely, or a least block it out. Anything would be better than watching hundreths of a second tick by.![]()
You can use Virtual Dub and Logo filter and add a black box as a logo over the timer, or use the Logaway filter and blur it out.
Hello. -
I like Logoaway, it works quite well. You can do a google search for it, d/l and install it into the Vdub filters folder. I use the x-y which covers up by "smudging" the surrounding video. Use the preview display with solid fill to fine tune then click x-y when done.
removed
By draven1968 in forum User guidesReplies: 0Last Post: 4th Aug 2008, 06:10 -
can this be removed
By tryintoo in forum AudioReplies: 4Last Post: 23rd Sep 2007, 12:23 -
Help,noise cant be removed!
By demonwarrior in forum Newbie / General discussionsReplies: 13Last Post: 16th Jun 2007, 03:10
