Hey, I'm Trying to put some Files in VCD format, onto a DVD-R, Heres my problem:
I can put them on it flawlessly... most of the time, so I know I'm donig it right. I chanegd the audio.. did all the settings like the guide says to. But this is what I get -
Half of the time, if not 90% of it... The last 2 video files on each DVD, or last 1 is choppy/Freezes/Restarts to the verry first menu. Never the first ones... they play flawlessy, but the last 1-2 of them never work, I got it to on 1 DVD-R, but thats it.
Now... It's not a burning problem, or a media problem. I ALWAYS burn my data onto a DVD-RW first, and try it in my player... if it wont play the last two files, it's garbage.. I erase it, go back, and try again. If by chance it plays both files... I put in a DVD-R, and burn it.. and the DVD-R plays it flawlessy too. So I'm doubting it's a problem with burning/bad burns... So I'm thinking maybe it's the software, turning it into Vobs/multiplexing it?
I tried using Ulead as the DVD burner, burning it directly to disk... And I also tried creating the Vobs for it, and burning the Video/Audio_TS folder onto a DVD-R, And in both cases.. the last file or two does the same thing. I used to think I was trying toput too many episodes onto a DVD -R, But Recently I tried to put on 6 40 min eps, instead of 10 like I used to, and it does the same problem.
My question is... Has anyone else ever had this problem? And if so.. how did you fix it? And do you guys know of any other software, that would allow you to burn as a VCD onto a DVD-R, other then in the guide on this page?(I figure you just need one, that wouldnt convert the MPG file, if it's in standard audio format...) Any ideas? (P.S - I have a 2.3 GHZ with 712 MB of ram... I don't do nothing while it's creating the DVD, so I don't think it's a computer problem, I think it has something to do with ulead)
Results 1 to 1 of 1
Question : Why i can't copy from Protect VCD
By indianguy077 in forum Authoring (VCD/SVCD)Replies: 23Last Post: 24th Mar 2009, 06:42 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43 -
VCD MPG1 file to CD Question
By Excelsior123 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 22nd May 2008, 19:14 -
Newbie question about VCD files for CD-ROM
By donn in forum Newbie / General discussionsReplies: 2Last Post: 13th Apr 2008, 17:37 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 01:36
