In the Recording Control, windows just let me choose 1 input device at a time, so i want to know if it's possible to unlock this and record from various input devices simultaneous.
like : Line IN & Mic ( both at the same time )![]()
Only if the option is there.
Creative soundcards have recording options like "What you hear".
Which is any sound selected under play options.
My Audigy has an option called "Analogue Mix" Which again is a mixture of inputs.
So unless your soundcard supports it then no sorry you can't as far as I know.
Fozzee -
i have a normal SB PCI 128.
in win98 everthing work fine, because this option in Recording controls don't exist, so win98 simply just record everything from all input devices.
But for a reason WinXP doesn't allow me to do this, i just have to choose 1 at time.
What driver are you using??
The XP built in one?
If you are try the Creative updated ones.
Or if your not try XP built in one.
I had the same issue when I had SB Live 5.1.
One or the other had a "What u hear" option.
Fozzee
help with capturing from various analog devices
By TARfan in forum Capturing and VCRReplies: 4Last Post: 19th Mar 2010, 12:36 -
Capturing old tapes to PC - devices and software
By Writech in forum Newbie / General discussionsReplies: 6Last Post: 12th Mar 2010, 16:06 -
VCD with 2 simultaneous languages in audio.
By v-sharp in forum AudioReplies: 9Last Post: 4th Feb 2010, 07:29 -
To coax output devices, only 1 input on TV, solution?
By Rudyard in forum Newbie / General discussionsReplies: 3Last Post: 4th Aug 2009, 02:22 -
Are there any good, cheap usb fiber optic input recording devices?
By yoda313 in forum AudioReplies: 7Last Post: 29th Aug 2008, 14:20
