Whenever I check the box in TMPGEnc 'Enable padding so not to go lower than minimum bitrate', whenever I try to play the file on the PC, the first couple of seconds of video play fine, then it freezes and the audio keeps playing.
Uncheck the box, encode same file, the problem instantly vanishes.
Why is this happening? How can I fix it?
I had some similar problems. First, Don't enable padding, I have found it causes other problems as well. I'll bet your playing back with an older version of PowerDVD. Yes? Upgrede. That video freeze will stop.
I've come to paint, but I've forgotten my brush.
Got Beer? -
Actually, I was using Windows Media PlayerOriginally Posted by BubbaLeroy
I agree, padding is a bad thing. I haven't had problems with playback on the computer, since I rarely watch movies on the PC. However, SVCDs encoded with padding enabled usually have playback problems on my set-top player.
How to set MINIMUM bitrate in VBR 2 -pass on TMPGEnc Authoringworks 4
By eltimbomofo in forum Authoring (DVD)Replies: 3Last Post: 9th Mar 2012, 16:59 -
Minimum Bitrate MPEG2 encoding
By Rob D. in forum ffmpegX general discussionReplies: 4Last Post: 14th Jul 2010, 10:44 -
Padding Audio to match Video Length with FFMPEG?
By boyer in forum Video ConversionReplies: 0Last Post: 31st May 2010, 11:13 -
Minimum PC Requirements to do HD Video Editing?
By dan1st in forum Newbie / General discussionsReplies: 5Last Post: 9th Jul 2009, 19:29 -
Resize video by padding
By tuanvn.2007 in forum Video ConversionReplies: 1Last Post: 19th Sep 2008, 10:17
