Is the light on the front of the DRU-500A supposed to blink while it is recording or is it supposed to be solid? While I'm recording the light flashes on mine.
The reason I'm asking is that I upgraded to the 1.0g and EZ CD 5.3.4.21 recently and it seems like its burning slower than normal.
For example, I burned about 43 MB to a 4X CD-RW today and it took around 65 seconds to burn the file (file speed ranged from 3x to 6x), but then took over a minute to finalize the CD (EZCD reported 3X during the finalize stage). I've been reusing this CD-RW, but no where near 100 times.
I then burned 1341 MB to a DVD+RW and it took between 6 and 7 minutes which I think is about right.
Definately flash............ well mine does anyway!
After doing the firmware upgrade to 1.0g did you remember to re-enable DMA for your Optical drives?
Had my burner about a week or so now and the first thing I did was upgrade the firmware to 1.0g from 1.0d. After the upgrade I forgot to re-enable DMA and found that ripping and burning DVD's ran very slowly. I suspect that this may be your problem.
Yes, it blinks for DVDR & CDR recordings unlike dome other brands.
Panasonic DMR-ES45VS, keep those discs a burnin' -
That's true, it does blink for DVD and CD music and movie disks. However, I did a couple of "software" disks on RW media, and the light stayed solid throughout the entire burn process. Seemed pretty interesting to me. Then when I did my next movie it blank off and on again. When doing DVD-R's for movies, on my computer, the SONY light blinks in unison with my hard drive light.Yes, it blinks for DVDR & CDR recordings unlike dome other brands.
While my sony was in working order YES, when it died, well NOP, and it died 15 days after day of purchase.
Cpu power is never enough
get rid of the blink defect due to frequency beating
By Umen Pich in forum RestorationReplies: 3Last Post: 28th Apr 2010, 20:35 -
/Sony DRU-190A problem
By Quadzilla in forum DVD & Blu-ray WritersReplies: 22Last Post: 7th May 2009, 15:10 -
Firewire External Enclosure for Sony DRU-500A. Help choose..
By donpedro in forum DVD & Blu-ray WritersReplies: 79Last Post: 25th May 2008, 12:52 -
Sony DRU-810A question...
By bamabluebird in forum DVD & Blu-ray WritersReplies: 4Last Post: 10th Jul 2007, 11:21 -
Sony DVD RW DRU-830A
By bjswitz in forum DVD & Blu-ray WritersReplies: 1Last Post: 30th May 2007, 09:41
