i'm not the only one with this problem, so if anyone knows what's going on... please help us!!!!!!!!
i have installed 42 ver 1.5 and when i drag the dvd icon to the drag and drop window in 42 it starts prescanning then a window message APPLE SCRIPT ERROR (CAN'T MAKE "0" INTO A INTEGER. (-1700)), if i hit the ok button the prescanning keeps on going and nothing happens.
this never happend before with the older version, i have already tried with the older ver. and this does not happen... is this a bug or what?
dj_yerba says: legalize it!
VIVA CHILE MIERDA! -
Dj Yerba,
I would try the usual troubleshooting steps to try to narrow down the cause
Follow the installation instructions completely on the read me files of 42 and read all documentation.
Throw away all of the old previously installed 42 application files and support files/folders and empty the trash
Reinstall 42 following all instructions and see if the problem still exists
If it does, then your system might be hosed. You might need to re-install os x 10.2.
Reinstall 10.2 jaguar by selecting custom install and choosing the archive and reinstall option and check the "save users and groups" option. Run software install several times until your system is up to date. THEN, reinstall 42 again and see what happens.
If you do all that and 42 is still misbehaving, then you have a case that maybe 42 is not playing right with your localized version of os x 10.2 since you said you were in chile. I would imagine they sell a localized version there unless you purchased it from the united states -
GuestYou should also run "Disk Permissions" in the Disk Utility application in OSX.Originally Posted by dj_yerba
Chose Repair Disk Permissions...
All of this especially if you have updated your OS latley. -
i believe you re right! i've aready checked my system "10.2"Originally Posted by superg
i 'm already downloading 10.2.4 combo update, so i'll give it a try and tell you later if it works ok or not.
thank you all!dj_yerba says: legalize it!
in addition to the above, the developers have said numerous times in numerous posts that they need more info than just describing the error. you need to describe your system setup (cpu, ram, free hard disk space, OS version, etc.), which dvd this is occuring on (they have said some dvds just won't work), and exactly what type of encoding you are trying to do.
don't complain that no one wants to help you. you need to provide the necesarry info to provide you with the solution.
i hope updating the os helps you. then others with this error will know that's what they need to do too! -
OK maybe i was i little bit too furious about it!, my apologies to all!Originally Posted by swampg8rs
But above every post there are some buttons where you can see my computer details, i believe you don't even have to press the button, just put your cursor over and a display will appear with that info.
About the movies... i know that not all the movies will work, but i have already tried them with the older version and everything went just fine, i mean the same movies i have tried before and nothing happens (all evangelion movies, and some others), and all worked fine, but not in the new 42 version due to the error discribed in my first post of this topic.
So why should i update if everything worked fine, cause there's one single thing i was never able to do with the older version.... SUBTITLES... that's why i need to update... to see if the newer version fixed that issue.
About the encoding, i tried standard VCD and standard SVCD.
And of course, if my experience on updating can help other people i will feel more than satisfied, cause there are a lot of people just like me who needs help. i've posted the same issue with another title "42 apple script error" and the only person who answer said "i have the same error". maybe that's why i was so furious about asking for help.
thanks to all the people who took their time to help in this post, i'll make my coments after the updating process to let everybody knows what happened.dj_yerba says: legalize it!
Ok... as promised here are my results after upgrading to 10.2.4
effectively after the upgrade 42 works... BUT, now i have another problem.
42 starts making the test and the test works, the xferring video process works but when it finishes does not generate the other files, and 42 says conversion complete and ejects the dvd and then appears a folder named "BurnWhatIsInThisFolder" and there's nothing in the folder.
What happened????? Please hhhhhhhhhhheeeeeeeeellllllllllpppppppppp!!!!!dj_yerba says: legalize it!
VIVA CHILE MIERDA!
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 23:53 -
K-lite issue then mp4 issue
By Arch3type in forum Software PlayingReplies: 0Last Post: 15th Dec 2010, 11:57 -
Is this a tracking issue or something else?
By HDClown in forum Capturing and VCRReplies: 4Last Post: 25th Apr 2010, 13:30 -
pc to tv issue
By notaclue72 in forum Media Center PC / MediaCentersReplies: 26Last Post: 25th Feb 2010, 13:25 -
Another issue...
By nanook in forum ffmpegX general discussionReplies: 3Last Post: 21st Nov 2009, 09:47
