Hi all-
I've had this problem with two seperate movies, both divx AFAIK... Using TMpeg 12.i, the video appears scrambled, almost like watching a VHS while it fast forwards; completely unintelligible, but it still has the right colors, with diagonal black lines across it. I've got divx 4.0beta installed.
Other divx downloads come out looking just fine. I recall from the divx4 install something about it causing havoc; could that be the issue? Sure would appreciate some insight!
TIA
Phatdaddy
Well, never one to wait for a reply, I went to divx.com, and got version 4.01... that did the trick. I guess something a little goofy was afoot with 4.0. Anywhoo, hope this helps somebody out there.
Phatdaddy -
Hi mate.
I get the same problem
, I get coloured blocks on my screen. sort of like scrambled. this happens when I convert an avi 2 mpeg using tmpeg encoder.
Any help would be appreciated
Thanx. -
Hey Gav-
Well, I let it (Drowning Mona) run last night... side by side with another divx download (Addams Family). The windows properties dialog didn't show them to be any different - I think it might be divx 4 vs 3; seems it used to provide better info in the properties tab?
anywhoo - using a goofball SVCD template, Addams went from a 712M divx to a 638M SVCD. Mona went from 705M divx to 1,197M SVCD; I also got the 99% 'error encountered decoding audio' thing from tmpeg (12.j) My SVCD's always give me hell trying to fast forward or rewind, but as near as I could tell, both mpg-2's played fine.
I'm going to try running it again tonight in parallel, maybe playing around with the specs on one, the other with no changes. If it still freaks out, I'll chalk it up to a bad divx (it has a strange resolution
But, it remains true that going to divx 4.01 allowed me to encode the file; that's an improvement!
Later-
phatdaddy
Encoding .Avi to Svcd?
By mrjust in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2011, 13:40 -
.avi playback, video is scrambled
By dough in forum Newbie / General discussionsReplies: 5Last Post: 11th Nov 2007, 13:19 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 11:41 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 16:56 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
