I have some AVI files that I would like to bring into DVD Studio Pro but since DSP will not import them I vae to comvert them into MPEG, How can I convert AVI to MPEG2 on a MAC OSX (anything but Cleaner)
Thanks,
Salud Diaz
Results 1 to 9 of 9
Me parece que tambien hablas espaņolOriginally Posted by salud
Well, everything depends on the framerate of your source movie.
First, open the Avi in Quicktime and watch in the movie information at which FPS (Frames per second) this movie is played. 25 FPS, 23.976 FPS or 29.97 FPS.
If you see 25 FPS ... reencode the movie with the same Framerate (25) in FFmpegX. If its played with 29.97 FPS you also will have to use the same FPS (29.97) in FFmpgX. But if its a 23.976 FPS source you have to reencode it at 23.976 and use the 2:3 pull-down option in the options window in FFmpegX, so yor DVD authoring appl. will accept it as a 29.97 source which you can import for ex. in DVD SP and that it will be still played at 23.xxx in your DVD player!
An instruction for FFmpgX you will find at the top of the topics in this mac-forum and a thread I started time ago at:
https://www.videohelp.com/forum/viewtopic.php?t=139259
Marcus
Hey Marcus,
Can you please guide me here?
My AVI settings are:
Format: DivX, 576 x 304 Mono, 48 khz, 16 bits
data sizw: 476.5 MB
FPS:23.96
data rate:104.2k
current size: 576x304
Based on this info which options should I have on ffmpegX?
example:
which tab should I use?
video, audio, options, tools
Which settings should I use in the tab?
Thanks, -
Go to the "quick settings" pop up. You can find at at the bottom of the FFmpgX window.
Choose "DVD- NTSC Hight Bitrate"
Now enter in the calculator the size in Minutes of your Movie an that it fits 1 DVD Media. Press "Calculate" now the optimal Kbit/s rate is entered automatically in the kbit/s window. Chose in the right field 23.967 (NTSC FILM)!!!
Got to the options tab and check also the "Gop headers" option!
And!!!! the "enable 3:2" checkbox, cause you want DVD SP to accept the 23.xxx Movie!!
In "tools" you will have to disable the "autohr as ...DVD" option and enable "keep elementary streams". at the right side disable "postprocessing ..."
REENCODE!
Markus
Hey Marcus,
As soon as I choose "DVD- NTSC Hight Bitrate" I get this error:
AppleScript Error
NSInternalScriptError (8)
And I click ok and then try to continue but no metter wat setting I choose I always get an error, her's an example of the most common erors:
Last login: Sat Feb 22 12:47:35 on ttyp1
pbpaste | sh
Welcome to Darwin!
[Sandro-Desouzas-Computer:~] sandrodesouza% pbpaste | sh
/Volumes/Mac2/goodies/movies/stwart_little2/Stuart.Little.2-PosTX.avi: Error while opening file
Encoding complete!
Thanks, -
I got this error message when OSx 10.1 was installed on my MAC.
Install OSx 10.2 and get the newes Apple Developertools at the ADC members site of Apple. Then it works!
Markus -
I have OSX 10.3 installed
Can you post a link for the tools you mentioned, please?
Thanks, -
http://developer.apple.com/tools/macosxtools.html
you have to sign in at the ADC members site -
When converting problematic .avi files to mpeg-2 it is recommended to run them into DivX Doctor II first (available from 3ivx.com) and to encode the resulting .mov instead of the .avi.
mpeg2 (4:3) to avi (16:9)
By kouras in forum Video ConversionReplies: 3Last Post: 3rd Feb 2009, 09:53 -
dv-avi(mpeg2) to avi compression
By nivek_nayr in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 12th Feb 2008, 08:44 -
MPEG2 to AVI conversion.
By fl3tty in forum Video ConversionReplies: 5Last Post: 4th Dec 2007, 00:31 -
4:3 source AVI to 16:9 mpeg2
By JoeMuskie in forum Authoring (DVD)Replies: 10Last Post: 10th Sep 2007, 08:52 -
avi to mpeg2
By n2lakers in forum Newbie / General discussionsReplies: 3Last Post: 23rd Jun 2007, 14:56
