With my work schedule I don't have a lot of time for stuff so I want the easiest solution available. The DVD Decrypter method for DVD-5 movies is so damn simple...just throw in DVD2ONE and RecordMax for DVD-9 flicks and I'm set...so darn simple! Quality looks as good as the original to me. How much can you lose from a 5-6GB movie going down to 4.5Gb?
Results 61 to 67 of 67
Originally Posted by JasonK
Working in the Beeb does that!
http://www.mrbass.org/instantcopy/gladeheateher.zip
http://www.striker2000.com/pics.zip
nuff sed! 8)
fair 1:1 transcoding/encoding comparions -
don't forget Road to Perdition. I said dv2one is superior than InstantCopy in this instance. Because IC could only get it to around 3.62GB. If IC fixed their calculations then it'd win.
http://www.mrbass.org/instantcopy/rtp.zip
I think I've pretty much decided on 5.2GB as my threshold. If DVDToolbox reports the size of the movie + AC-3 6CH audio and subs is 5.2GB or less (but higher than 4.37GB) then I'll use dvd2one. If it's greater than 5.2GB than I'll use InstantCopy. If I can get it below 4.37GB then I use DVDToolBox which is twice as fast as dvd2one (8mins vs. 15mins)
In other words I'm only going to let dvd2one transcode and reduce it by around 800MB or so. Anything more I don't think I'll like the results. Gladiator is 6.22GB so that is definitely IC7 no questions about it. -
Originally Posted by mrbass
I'm lucky and got in early and got a 'free' copy of DVDToolbox, in fact I used it when it first came on the scene a few months ago and found it great to use before IC came on the scene and gave me the option of menus also with very high quality results
I agree with mrbass if it's less than 4.37Gb why use DVD2One unless you want menu's?
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 02:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 10:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 10:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 06:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 16:11
