OK, here's the deal.
Using TMPGEnc, I am trying to convert a Divx movie ("Tombstone") to an MPEG and I am having problems setting up the screen size for when I play it on my DVD player.
According to Virtual Dub, the file is frame size 512x224, 29.970 fps meaning I load NTSC when I encode. I do that and in "Settings", under the "Video" tab, the options go away and the Size is 352 X 240 and Aspect Ratio is 4:3 525 line (NTSC). So far so good.
Now, here lies the problem. In "Settings", under the "Advanced" tab, I have Source Aspect Ratio set to 1:1. Now if I set the video arrange method to to Center(Keep Aspect Ratio), the image isn't streched and I should be satisfied but there is still the matter of that teensy 10 % overscan that nearly all TV's have. I have a feeling I should do something with Center(Custom Size).
So my question is how do I set up the Center(Custom Size) so that when I play it on my DVD player the movie will be the right size(meaning NOT stretched) and it will compensate for the overscan area by being 10% smaller in height and width.
Any hints or help will be greatly appreciated. Thanks in advance.
Try (just encode a small file) to 352 x 288 with the ratio 1:1 and another with 352 x 244 with the ration 4:3 and another 352 x 240 with the ratio 1:1
Sorry, it's no good. The MPEG files were streched vertically for all of them (the middle one more than the other too)! Which leads me to another question. Is the way the MPEG file looks when viewed the same as the way it will look on your DVD player?
Anyway, if there are anymore possible solutions to my problem in the first post, feel free to mention them. Thanks in advance. -
https://www.videohelp.com/forum/userguides/91597.php
ignore the parts about low resolution for doing this. That should do it for you. If that doesnt work, download dvd2svcd, which will do everything for you (be sure to mark the output file as mpeg 1.
GOP control in ffMPEG MPEG1 encoding
By Computer Nerd Kev in forum Authoring (VCD/SVCD)Replies: 12Last Post: 4th Jul 2011, 02:52 -
can i truncate mpeg1 video files without re-encoding?
By dullrazor in forum Newbie / General discussionsReplies: 2Last Post: 22nd Nov 2009, 15:47 -
Trying to add a small intro clip to a movie file without re-encoding
By solar2504 in forum Video ConversionReplies: 11Last Post: 19th Mar 2008, 09:19 -
By solar2504 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 18th Mar 2008, 01:53 -
190Mb movie file NEED it smaller -4 Mb. Encoding issue?
By famreeks in forum Newbie / General discussionsReplies: 1Last Post: 16th Jan 2008, 07:06
