I have finished ripping a DVD to my Hard Drive using "TMPGEnc 2.59", I used a Bitrate of 900 BPS, I wanted to put it on one CD, But when I tried to burn it to a CD using "VCD Easy" it told me the Image was too big. the disc I was trying to burn it to is an 80 min cd. My question is, Do I need to redo the TMPGEnc process, and set the bitrate lower then 900 bps, or where did I go wrong? I have been unable to adjust TMPGEnc using the start up Wizard, because it is the free version, but I was able to make my adjustments on their main screen. Thanks in Advance...
What is the size of the MPEG file? A 80 minute CD can hold approximately 800 meg when recorded mode-2. You can maybe get an additional 15-25 meg if you overburn.
get rid of tmpgenc 2.59. that has a bug that makes files larger than they should.
also this calculator lets you know how much bitrate to use in your movie so it'll fit on 1 disc - https://www.videohelp.com/calc.htm
Problem With Easy RealMedia Producer 1.94
By nazim in forum Video ConversionReplies: 7Last Post: 16th Jun 2011, 12:34 -
Help for easy editing (problem with mpeg-2)
By angamandi in forum EditingReplies: 39Last Post: 28th May 2009, 21:15 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 21:57 -
VCD Easy
By kshavo in forum Authoring (VCD/SVCD)Replies: 10Last Post: 12th Feb 2008, 14:43 -
What is the problem with audacity? Can't do easy editing?
By happydog500 in forum AudioReplies: 10Last Post: 30th Sep 2007, 09:38
