I have a problem making PAL DVD's from NTSC film source. This is what I do:
o Get 24 fps AVI
o Save audio out as a .wav
o Use MediaPipes to change the video framerate to 25 fps
o Use 'WavWorks' to speed up the audio.
When I examine the 25 fps mpeg2 and the speeded up audio they are the same size - accurate to within 1/100th of a second. But when I combine them the audio and video are out of sync!![]()
Sync is lost immediately - this isn't a gradual drift - does anyone know what's going on? Even better - how to fix it...
I also made DVD-Rs of my 24 FPS AVIs but why do you change the FPS to 25 and author a PAL DVD????
I am sure that the soundtrack of your 24 FPS AVIs also is in english??!!!
So reencode the 24 FPS Avi in FFmpgX at 24 FPS and check the 2:3 Pulldown option in the options window. You will receive a (29.97) FPS movie which you can import in DVD SP and it will be played back at 24 FPS, so Video and audio will be in sync.
After this author in DVD SP a NTSC!! DVD which also will be played back in your PAL DVD player!
So, ... forget PAL if you have english AVIs playing at 24 FPS!
Here's a thread I started a time ago and some users gave me good instructions to use the 2:3 Pulldown in FFmpgX! :
https://www.videohelp.com/forum/viewtopic.php?t=139259
Markus
HD 50 fps flv conversion sync Hell
By Arlich in forum Video ConversionReplies: 0Last Post: 11th Jul 2010, 15:01 -
Sync 29.970 FPS audio to 23.976 FPS video?
By LCO1971 in forum Newbie / General discussionsReplies: 3Last Post: 13th Sep 2008, 15:23 -
Conversion out of Sync, probably cause=FPS?
By Day44 in forum Video ConversionReplies: 2Last Post: 7th Jul 2008, 14:30 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 19:17 -
H264 to AVI out of sync even though same fps was set.
By sooojaded in forum Video ConversionReplies: 4Last Post: 15th May 2008, 02:09
