Missing MPEG Tools
Using the .xml creator in Missing MPEG Tools I attempt to add a folder of mpegs, as it says. But it only accepts 9 sequences. Am I missing something, or is that all it accepts?
My other question is that when I burn my disk every mpeg plays perfect except for 2. I looked at the info of both of them and they are the only ones that don't have 224kbs audio. One is 192 and the other is 320. They are both MPEG1 Muxed mpegs. Would this cause them not to play correctly? How can re-encode the audio to 224?
Missing Menu Generator
I created a vcd with a menu and it work fine until I attempted to play the mpegs. They both played back at about half speed. Is this caused by the menu or could it possibly another problem? It played at real time on the computer.
MMT vcdxgen tab – the code used is *.mpg, (wildcard name with .mpg extension). So, it should pick up all mpegs in the folder, (up to a limit of 99).
VCD format only allows 224 kbps audio bit rate, whereas svcd allows a range of 32-384 kbps.
MoreMissingTools has decode MP2>WAV and encode WAV>MP2. (default 224 kbps)
MMG – there is nothing the the menu generation that would affect the playback speed. -
So it skips *.mpeg. I'll rename them thenOriginally Posted by Ross
I'll give the re-encoding of the audio a try and let you know how it worked. -
Okay I renamed all my mpegs to .mpg, but it still refused about 1/4 of them. When I made the .xml and tried to make the image it said that the mpeg had to be fixed. So how to I fix the mpeg? On the ones I did get to work I burned as a SVCD and it played pretty good, except for about 3 of the videos the audio started playing, but the video never showed up....any ideas why this may have happened?
mmg problem ( The codec's private data does not match)
By Umen Pich in forum EditingReplies: 6Last Post: 19th Sep 2011, 22:32 -
converting video from 4:3 to WS and from WS to 4:3 & other questions
By rockerman in forum Newbie / General discussionsReplies: 5Last Post: 16th Dec 2010, 06:20 -
Muxing MKV file with mmg (mkvmerge)
By HAL4711 in forum Newbie / General discussionsReplies: 4Last Post: 9th Jul 2009, 18:49 -
Newb questions - re. HD&MiniDV Camcorders & Capture
By The Big Cheese in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Jan 2009, 17:21 -
his ipod questions?
By joyy in forum Newbie / General discussionsReplies: 1Last Post: 23rd Jan 2008, 02:15
