i recently ripped a movie that was 5gb, after i dumped the French, Spanish, and German 5.1 audio tracks, the movie was 4gb, and i got wondering, how much room do subtitles and audio tracks acctually take up ??
it was the first time i had ever just ripped the movie and dumped the redundant soundtracks, and it played on my standalone..
well happy
" Your gonna need a bigger boat .... "
Well...
It depends on what bitrate you use (of course).
Most Dolby Digital 5.1 files uses bitrates of 384 kbit/sec or 448 kbit/sec. DTS files are much bigger though (bitrate 1536 kbit/sec), so the size depends on the bitrate factors. Most likely 1 hour of dolby digital 384 kbit/sec may be something like 140 mbytes of size(I haven't calculated it exactly). You could also extract an ac3-file from one vob-file to check the actual size of it. download a vobtrailer and use TMPGEnc...I wanna be bigger, stronger, drive a faster car...
Ripping a Track Out of an AC3 File?
By SLK001 in forum AudioReplies: 0Last Post: 18th Mar 2011, 00:10 -
Audio track shorter than video track in MPEG Video Wizard DVD?
By xxxyyy in forum EditingReplies: 3Last Post: 30th Jan 2011, 13:24 -
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 12:25 -
After using DVD-RB, is there enough room to make DVD menus?
By sldvd in forum Newbie / General discussionsReplies: 4Last Post: 3rd Apr 2010, 23:23 -
How to select audio track opening multi-track container in avisynth?
By lovyagin in forum Video ConversionReplies: 7Last Post: 23rd Sep 2009, 12:16
